Modern vehicles are smarter, faster, and more advanced than ever โ and now, your tuning tools are too. HP Tunersโ all-new MPVI4 is the next evolution of their industry-leading OBDII interface, delivering the performance, precision, and reliability todayโs enthusiasts demand.
Whether youโre tuning for more power, improving fuel economy, or simply learning what your vehicle is capable of, MPVI4 is your connection to it all.
What Is MPVI4?
MPVI4 is the latest generation OBDII interface from HP Tuners, designed to connect your vehicle directly to VCM Suite, HP Tunersโ complete tuning and diagnostics software.
Through this single device, you can read, edit, write, and log data from your vehicleโs control modules with unmatched speed and accuracy. Itโs built for both professionals and enthusiasts โ anyone ready to take control of how their vehicle performs.
MPVI4 pairs seamlessly with VCM Suite 5.2, the newest version of HP Tunersโ software, for the most advanced tuning and diagnostic experience yet.
Performance and Precision
Every generation of HP Tunersโ hardware has pushed the limits of whatโs possible โ and MPVI4 is no exception.
- Dual-core 1.7GHz processor with 1GB RAM โ over 30x more memory than MPVI3.
- Standalone data logging performance on par with VCM Scanner, providing the same level of speed, clarity, and accuracy trusted by professionals.
- Refined tapered OBDII design for a stronger, more reliable connection every time.
These improvements mean less waiting, cleaner data, and a faster, more responsive tuning experience across every supported platform.
Scan. Diagnose. Tune.
At its core, MPVI4 is designed to make custom tuning straightforward and repeatable โ whether youโre in your garage or on the dyno.
Using VCM Suite, your tuning process follows four simple steps:
- Read your vehicleโs stock calibration with VCM Editor.
- Edit key parameters like fueling, ignition, or transmission tables.
- Write the updated calibration back to your vehicle using MPVI4.
- Log performance data with VCM Scanner to verify your results.
Each step is faster and smoother than ever, with cleaner data and precise control that lets you focus on results instead of setup. With enhanced scanning performance matching the precision of VCM Scanner, MPVI4 makes data capture and analysis more efficient than ever โ whether youโre troubleshooting, logging on the dyno, or refining your tune on the road.
Compatible with More Than Ever
MPVI4 expands HP Tunersโ already extensive platform coverage, offering support for thousands of vehicles from 40+ manufacturers.
From high-performance sports cars and daily drivers to trucks and powersports, MPVI4 gives you one tool for your entire lineup. Itโs fully compatible with PROLINK+, allowing users to integrate analog and CAN data inputs for enhanced monitoring and diagnostics.
No matter what you drive, or how many vehicles you tune, MPVI4 keeps you connected.
Built for the Future
Underneath its refined design, MPVI4 is built on a modern architecture designed to grow with you.
With Bluetooth 5.2 connectivity and built-in hardware for future Wi-Fi integration, MPVI4 is ready for new features, firmware updates, and expanded support as HP Tuners continues to innovate.
Whether youโre scanning data at the track, tuning at the dyno, or logging performance off-road, MPVI4 is ready for wherever your tuning journey takes you.
Getting Started with MPVI4
Getting started is simple:
- Download VCM Suite 5.2 from HP Tunersโ website.
- Connect MPVI4 to your vehicleโs OBDII port.
- Open VCM Editor or VCM Scanner to begin.
HP Tunersโ Help Center, video tutorials, and online community make it easy to learn every step of the process, from your first scan to your first custom tune.
Conclusion
MPVI4 represents the next generation of vehicle tuning technology. Itโs faster, smarter, and more capable than ever โ empowering you to scan, diagnose, and tune thousands of vehicles with one device.
Whether youโre chasing horsepower, fine-tuning drivability, or optimizing your setup for the trail, MPVI4 is built for every driver and every build.
MPVI4 โ Tune all the toys in your garage.
We won’t leave you hanging – Throughout your tuning journey with HP Tuners, utilize our Help Center, Forum, Educational YouTube videos, and technical support team for any help you may need.
